I would like the ability to lower opacity on clips that have filters on them.
Ability to lower opacity on filtered clips
Gigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...Tags: None
What is holding you back doing it now?
It is possible.
I moved this to the normal forum as for now it does not look like a feature request.
Enable the mix and drag the opacity slider to any value you want.Last edited by GrassValley_SL; 08-30-2011, 05:04 PM.
As I understand it, the OP is after the ability to raise or reduce the power of individual filters.
@zvit, have you checked out "Blend Filters"? This may do what you're after.Rusty Rogers | Films
Originally posted by zvit View PostI would like the ability to lower opacity on clips that have filters on them.Andreas Gumm
post production / authoring
Windows 7 Ultimate,
GV hardware: 3G Storm
PC 2
GV hardware: HD SPARK
Originally posted by mattmatt View PostThis is doable! Use the Blend Filters filter and adjust the intensity of your filter by keyframing between "no filter" and the filter you want to adjust.
It's a decend start & it could be the goal for some filters if we get some more advanced features for easier keyframe precise workflow!
OnAndreas Gumm
Windows 7 Ultimate,
PC 2
Originally posted by Andreas_Gumm View PostNot really, because keyframes can't be set framewise!
OnWhen I go out, I wear my EDIUS T-Shirt.
Never would thought of it myself but after Matt's video when using the blend filter inside the mask filter, the possibilities are endless.
Old users are indeed used to work arounds, even fading effects in the same clip using cut and desolve on it to overcome certain issues like key framable but not smooth changing YUV filter.
This has been brought up in version 4 then 5 and now 6 but indeed it is doable.E5.51 + E6.05 / NX HD / Win7 x64 / intel X3366 / 9800 GTX+
Imaginate 2 / TMPGEnc VMW5 / TMPGEnc AW4 / WaveLab 4.
I am SOOO sorry, I made a mistake in my question. Of course you have access to opacity keyframes on filtered clips!
What I meant was the transitions that get placed on one clip (not a dissolve between 2 clips) like in the attached picture.
Should I start a new thread?Attached FilesGigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...
