Low Quality Export DV Pal 4:3 25F
  • Low Quality Export DV Pal 4:3 25F
    I am working on Edius 5.5, now wen i am exporting my project i get a low quality, i u se the DV PAL exporter and then i burn on Encore, or the Disk Burner in Edius and still i get a low quality.
    And somtimes i just cant sent the project from the timeline 2 disk burn.
    How long is the timeline ?
      you can export to mpeg es from EDIUS timeline at fast speed and this will be accepted by Encore without further processing
        the timeine is about 1 hour or 1 and a half no more than that...
        i wik try the MPEG 2 but still i will nid the AVI file Export that will b in high quality and not crap
          what do you wish to do with the DV avi? it is of no use for Encore or the EDIUS disk burner
          if you export timeline to Canopus HQ fine, you will have a high quality avi
          the Disk burner can't be used when your project setting is progressive, it must be interlaced
