I've got a problem with the Blu ray I've encoded, when I burned direct from Edius I had an error code 83450408 so I had to abort but the disc content was complete? the problem is the audio peaks on loudish sections,(Power DVD) I've played the stream and it doesn't peak, I've played other Blu rays that I've done and they're ok but I used IMGburn for those, when I try imgburn by dragging in BDMV and CERTIFICATE I get a strange file arrangement ie BDMV\BDMV and BDMV\CERTIFICATE but assumed that was ok? checked all the other settings When I burn and verify the disc it won't play (tried 2) and a message ' format disc windows cannot play this format' what is wrong here? can anyone help? and is there a virtual player I can use to play Blu ray? Power DVD 9 will play blu ray discs but not from the hard drive as it does video-TS
Mick
Mick
