When i use After effects 7 to import the avi which render form eduis4.5 use HQ encoding, After effects says "no such avi compressor", I had try to open which capture long time ago use "conopus" encoding, it also can't import.
i try to render from AE7 use HQ encode, "ERROR"
sure i can see all the footage on edius or windows media player but only AE7 can't read.
any suggestion!
any suggestion!
