Slow Motion / edius parameters
  • Slow Motion / edius parameters
    Hi EVERYBODY,
    i'm french, i'm on edius 6.0,
    i have shot in slow motion a kung fu battle with an AF101,
    it has been shot in ntsc 59 94 frequency, 1080 30p,
    60 fps,
    when i look my footage (AVCHD native) on tv, it s great,
    when i edit them on edius, i have some ghost move,
    i have changed the parameters in fullhd 25p, fields are in progressive,
    i have still that ghost that i dont see in native,
    thanks for helping me to configure well my project,
    i would love to show you soon the video.
    thx for support
    ntsc to pal will always give bad results
    your only hope is tick USE NEAREST FRAME in the speed box
      hello,
      my pc is not pal lol,
      you cant rec in slow motion if you are not in ntsc,
      when i change speed frame it changes nothing,
      when i read my footage on vlc, i have no ghost, it s completly fluid.
        am confused - what is the actual frame rate of the footage - make sure the project settings match this and you wont get ghosting
        right click on the file and select properties - the * next to the frame rate number is the actual frame rate of the file.just make sure the project is set at this rate too
          no matter,
          the frame rate is 29 97
          the project properties is 1920 1080 25p
          thx for your help
            AM I THE ONLY dude to be block in this hell's trouble !!!!!!?????
            i felt alone in the space where nobody can HEAR ME !!!!!!!
              If the frame rate of your footage is 27.97 is is not 60p.
              Can you post a screen shot of
              1 your project settings
              2 property window of the clip . (select clip press alt+ enter)
              The information you have provided is confusing.
              Let us see what you have so we can help you.
                thanks,
                i did a mistake,
                my footage is 1080 30p
                it s ntsc,
                i have no ghost when i open the same footage in a ntsc edius project,
                my big trouble now is that i can t switch pal project to ntsc project,
                so I HAVE TO DO ONCE AGAIN ALL MY EDIT !!!!
                please confirm that we cant move from an full hd pal project to an full hd ntsc project.
                here is the video with the ghosting
                www.myspace.com/deadlinz http://jeetcenter2003.free.fr/ Thx to: Sylvain & Julien Cadreur: Jérôme Thomas, Alban Despujol & Julien Balestier Real…
                password : jeet
                  Do you see ghost when you just playback at normal speed?
                    can you explain what you did in order to shoot slomo? do you mean you switched camera to 60p and then when you place it on 30p timeline, you go to clip properties and change frame rate to 30p, this will then play the clip smooth at half normal speed
                    is that what you did?
                    btw: NTSC footage on Pal timeline will not look smooth
                    I am surprised the camera can't shoot 50p, then you could have perfect slow motion in Pal 25p project
                      It shoots 50p.
                        Originally posted by GrassValley_SL View Post
                        It shoots 50p.
                        that would have been the way to go
                          How many threads of this topic do we have now? I can't remember
                          where I have posted responses.
                            Yup
                            I shot with an af 101 you can t use vfr in pal. When you rec in vfr it s'recording in slow motion, you dont have to slow the clip, the native footages are still slow. The quality is perfect when the camera is well configured. You must be in freq 59 94 using 1080 30 p. You may know that the ghosting is created by the bad freq pal parameter project. I tried everything in pal, it changed nothing for the ghosting.
                            I took a paperbook and wrote all my edit...today i ll re do the edit.
                            I learnt one thing : never forget the first step before climbing on the top of the world :)
                            I tried to import in aaf edl, i tried to import my sequence, the freq blocked everything so...this is a second thing i learnt, You Can t switch to an ntsc project when you are in pal, it might be a good thing possible for edius 7 ?
                            Peace
                            Thx for support
                              If you want good slomo , you need to shoot it at 60fps or 50fps, not 30fps.
