EDIUS does not capture when I connect my DV camcorder
  • EDIUS does not capture when I connect my DV camcorder
    G'day,
    I'm a newbie here so I hope this is the right forum ... if not please let me know which one to use.
    Formerly used DVRaptor and DVEdit with my Sony DCR-TRV410E and captured w
    ithout any problems.
    I've just updated to EDIUS NX PCI-e. Followed all the install instructions but don't seem to be able to connect/capture from sony DV cam.
    Does anyone have any clues or sites I can go to check I've set the beast up correctly.
    Thanx
    mikmak
    Get a new camera.
    Trey Sharpton
    In His grip!
      Originally posted by treysharpton View Post
      Get a new camera.
      Rather extreme advice?
      Mikmak: When you say you're having trouble - are you getting any error messages? Or is it that you simply have no device control?
      Do you have a basic onboard FireWire port that you can connect to on you PC, just to try and isolate the connection issues?
        As KH says, can you capture with any other app, if using Windows can you capture with Movie Maker? At least we'll then know that the cam/cable are ok.
        Have you set the capture to the nx dv port in the initial capture settings?
        Graham
        www.myvideoproblems.com
          Do the project setting match in video color format?
          Do you have the correct input chosen?
          Do you choose correct capture settings .
          You have to provide information for us to help.
            hi I have exacly the same problem with sony DCR-PC110E PAL. I`m able to capture footage in Windows Movie Maker, Premiere Pro etc. When I click CAPTURE/NHX E2 DV i see just something like this - http://www.fotaze.pl/img.php?id=2919 What`s the problem??
              looks like you did not select Pal in input settings of capture dialogue
              you need to click 50i
                I`ve done it. I checked panasonic camcorder as well and panasonic works. Hmm
                  Welcome to the Forum mikmak and congrats opn the NX!
                  Go through your settings and see to that Edius is not expecting HDV while your camera feeds DV. (My first mistake with Edius... not my last ;)
