Track mapping
  • Track mapping
    at least 10 times per day, for no reason at all, track mapping enables itself (audio lands on A1 track), it happens when dragging a clip from bin to timeline VA tracks
    I then have to hit undo, then clear all tracks, then drag clip again and all is well until the next incident
    I have not figured out the exact thing I maybe doing that could cause this
    has anyone else seen this happen?
    I've not had it happen yet, but I'll let you know if it does, as I'm just about to add loads of clips to the timeline in a huge project.
    So far I've only done conversions, so it's one huge file after another.
    Graham
    www.myvideoproblems.com
      Noticed this since I installed the upgrade to 4.5, been thinking it's something I'm doing wrong until you mentioned it. Yep, drag from bin to timeline and it wants to put audio on A1 track, blast!
      Claire
        I mentioned that behaviour when i did ask in a thread about channel mapping(as this appeared as an annoying thing to me...)
        I am not sure if this was happening in previous versions, but i noticed that i can change it just when you change the order of the Channels(on he left of the timeline..).
        So if Track one is set to a1, the clip you drag down will always jump there, but if you make, lets say Audio-track 5 to be Mono A1, the clip will go there...still annoying, as we should be able to drag the audio wherever we like to, but a workaround..!
        Edius 6.52
        Windows 7-64bit
        8GB RAM
        Intel Core I5, [email protected],40GHz
          Edius Annoyances
          Yes, this happens all the time. I take this as just another annoyance where Edius does it's own thing. I wish I would be able to get a program where I can have control over what is happening.
          Ted
            Could it be that you guys accidently hit a shortcut keyboard and track mapping without knowing it until you start draging stuff up to the timeline?
              Track Mapping
              Can you explain to me where the default shortcut key is since I have not created any keyboard shortcuts on my computer.
              Ted
                Application Settings | Customize | Keyboard shortcut
                There are many default shortcuts. And you can use the tool in the sticky to translate your exported settings to human-readable text.
                  Ted
                  Oh boy, if you learn or mapped your keyboard shortcut to your preference, you should be able to edit 20 times faster, and that is no joke.
                    Remapped
                    Ok, I have been working through a one hour video with well over a hundred individual clips, all with audio. I have 5 video tracks open but only VA 1&2 have audio enabled. I have been able to drag each clip to VA line 1 then separate them as I desire. Tonight, I turn on the machine to resume my work, but now I drag a clip to VA 1 and only the audio goes there and the video goes to Title Track 2. I have tried dragging video clips that I have already placed on the VA 1 last night, but they separate as well to the same places. How do I get this back to the regular way where I can drop a video clip on VA1?
                    I'm still using EP3.
                    Ken,
                    Edius 5.12 2XOpteron 280s, K8WE, NX, SATA 1Tera, Radeon Extreme X850, 24" Dell LCD and some other 17" LCD, Pioneer BD-RW BDR-205(1.02),
                    Sony Cams; FX1, FX1000, FXR-7.
                    Owner - D&J Video Productions
                      I think this just started happening to me...
                      Randomly, track mapping will turn on and it will look something like this:
                      I have to turn it off (Clear all)
                        I have been editing with 4.51c for a week now and have not seen it, could it be that because I only use 1 1VA track and the rest I split the audio to audio track.
                          Ok, I think I found it. There is a small v window on each VA track. Somehow mine got clicked off, but I'm still not sure why video was going to the Title track. Remember now, I'm still using EP3.
                          Ken,
                            Ted
                            When a audio track is selected if you press the "1" on the keyboard it will map the first channel to track one.
                            I do not want to discount the fact that a bug could exist but I wonder if some of it could be a key stroke since it is so easy.
                              If you go to the left of the timeline and look for a tiny capital A; right click on it and select 'clear all tracks', then you will be able to place your audio wherever you desire. In spite of what it sounds like, it will not delete any clips that you currently have on the timeline.
                              Ted
