I am having trouble capturing HDV using Edius 4.51c. Camcorder: Sony HVRZ1U.
Capture Procedure:
1) Start Edius 4.51c
2) Select New Preset at the New Project list. (The Project Settings dialog appears. Edius displays a message "Multiple output devices are found. Please select your output hardware.)
3) Ok the message.
4) Select "Generic OHCI HD 60Hz" for the Output device.
5) Select "1920x1080 59.94i" for the Output format.
6) Select the default values at the New Preset dialog.
7) Select the Start button.
8) Define a project folder and a project name in the Project Name Setting dialog.
9) Select the Capture menu.
10) Choose "Generic HDV - Input"
11) From the Input Settings dialog, choose "Generic HDV Input" from the Input Device list.
12) Choose "Canopus HQ 1920x1080/59.94i" from the Input Format list.
13) Define an In and Out point in the PLR window.
14) Click the "Add to batch capture" button
15) Open the Batch Capture dialog.
16) Define a folder and filename in the filename column
17) Select the Capture button.
Edius does not capture the video and the Staus progress bar does not display. This procedure worked in Edius 4.1.
Capture Procedure:
3) Ok the message.
