edius and plural eyes
  • edius and plural eyes
    plural eyes does not seem to work in edius 6.03. tested the trial version of plural eyes and seems that it does not align the different cameras at all in multicam. anybody has tried this?
    It's only supposed to work with unlinked audio, but I have yet to get it to do anything.
    I have a feeling they're working on it.
      ok ill try to check it unlinking all audio tok the video. but seems to work on the previous version, been using in my 6.01 without unlinkking those audio. but anyways thanks for the response
        unlinked the audio but no luck. it will not sync the audio. same as the video they are not sync.
          I had some earlier success but my last effort just wouldnt work just showed as 2 clips un synced maybe a W7 update has disturbed something
            Hey Guys i am having the same issues... i think i will ask them for a refund as its not working... I was using Plural Eyes on Edius 6.02 No Problems, got it to sync 3 camera's with audio without fail. Now after the install of 6.03 i keep on getting errors and it will not work... i think a waste of money...
            Many thanks
            Dipesh Parmar (DIP)
            Unreel Eyes - http://unreeleyes.com
            Hardware Used with Edius: -
            (3 x System with : - Intel i7 X990, Asus P6T Deluxe V2M/B, 24GB DDR3 Ram, Leadtek FX5000 & FX4000 Quadro Card, 2x 2TB Raid (1+0) Hard Disk Drive Setup, 6TB x 4 Network Storage Drive, Pionner & Sony Blu-Ray Drive, Firewire 800 + 400 PCI-e Card, Canopus NX PCI-e Card with Breakout Box, Canopus edius 6.51, 6.51, and edius 6.07).
              Since 6.03 just came out, you might give Singular a chance to come out with an update of their own. Did you report the problem to them?
                My problem was with beta 2 in 6.02 just stopped working never found beta 3
                  We're testing 6.0.3 here and it seems to be working fine. If you are seeing problems please send us a screen shot of the error message, or even better, the project and log files as described here.
                  If there are problems with 6.0.3 we will definitely fix them.
                  Bruce
                  Bruce Sharpe
                  Singular Software
                    Working fine here in E 6,03
                    JoiCam´s
                    And more
