Deleting / modifying project presets?
  • Deleting / modifying project presets?
    I have a project which I have been editing using with an incorrect preset.
    If I modify or even delete this preset, will it affect the existing project or just future ones?
    Modifying the preset should not affect the project. It is like changing from an HD setting to SD. You can't change the frame rate but you can change field settings. As far as new projects, as long as you use that project setting until you modify it the original settings will be there each time.
    On this screen shot you will see the modify button. Once you make your changes here they will be permanent.
      Thanks Jerry,
      I know that I can modify the preset. I just wanted to know if it would mess up the exisiting one.
