blue ray length
  • blue ray length
    on a standard dvd i can get 2 hours max.
    how much will i get on a 25gb/50gb blue ray.
    You can get more than 2 hrs on DVD ... I can get 3 hrs 56 on Bluray (25GB disc). The matter is what quality do you want (bitrate) ?
    Asus P5WDH Deluxe w/E6600 - 4GB Corsair - 8800GTS - 1TB & 1.5TB (2x750GB RAID 0) - Antec P180 + Trio 650W - XP Pro w/sp3 - NX PCIe w/Expansion Card - Edius 5.51
    Asus P6T i7 920 @3.6 - 12GB Corsair Dominator - GTX275 - 1.5TB & 3TB (2x1.5TB RAID 0) for Video - Antec P183 + Corsair HX-750W - Win7 - Edius 6.07 - Firecoder Blu - PC3.05.91 - BDR-203 - TMW5 & TAW5
    Asus P6T i7 930 - 12GB Corsair - GTX260 - 1TB & 1TB WD Black for Video - Antec P183 + TPQ-850W - Win7 - Edius 6.07 w/HD Spark - BDR-205
      the best quality 2 hours (25gb)
      SUPERMICRO 7046T-NTR+ CPU DUAL XEON X5680 3.33 GHZ nVidia Quadro K2000D 2GB DDR5 32GB OF RAM WINDOWS 7 x64 ULTIMATE 8TB SEGATE RAID 1 & 8 ΤΒ WN STUDIO II MY BOOK RAID 1 & 8TB e-sata RAID1 CANOPUS SP FOR HDV FIRECODER-BLU EDIUS 5.5 EDIUS 6.08 EDIUS7.03 ADORAGE IMAGINATE 2 BD LG PROCODER 3 CANOPUS STUDIO CONTROL BOX PANASONIC AG HPX301 P2 AVC INTRA100 AJ-PCD20 P2 DRIVER PANASONIC VIDEO AJ-D250 DVCPRO CAMCORDER AJ-700E DVCPRO AG-HPX250Ε
        If you use H.264 you can get a lot on a single layer BD. If you want to get max possible with good quality, you have to use 2pass VBR with H 264, but the encoding might take a long time and you have to use another encoder besides the EDIUS AVC encoder. If you want to save time, use BD50 (cheap on eBay) and you can get 5 hours on a single disc with excellent quality using the EDIUS AVC encoder.
          hey there, It really depends on what sort of QLTY you are after, i have been about to get 4 hours on a STD DVD, compressed to the max and the footage look ok. however you should stick to about 2hours to get good QLTY, with Blu-Ray Media the same deal, the Higher the QLTY the less the Hours... but normal you should be able to fit about 4 hours onto a Blu-Ray Disc without loosing QLTY... there are alos Dual Layer 8.5GB DVD Media, and Blu-Ray media is also AV in Dual Layer 50GB
          Many thanks
          Dipesh Parmar (DIP)
          Unreel Eyes - http://unreeleyes.com
          Hardware Used with Edius: -
          (3 x System with : - Intel i7 X990, Asus P6T Deluxe V2M/B, 24GB DDR3 Ram, Leadtek FX5000 & FX4000 Quadro Card, 2x 2TB Raid (1+0) Hard Disk Drive Setup, 6TB x 4 Network Storage Drive, Pionner & Sony Blu-Ray Drive, Firewire 800 + 400 PCI-e Card, Canopus NX PCI-e Card with Breakout Box, Canopus edius 6.51, 6.51, and edius 6.07).
            If you are putting that much onto a disc, your definition of 'looked OK' is far different than mine. Four hours on a BD without loosing quality, sorry...Are you delivering to clients with that much on a disc? Hopefully, there is little to no movement in the video. It will show up with those low bitrates.
              i am doing Video from Edius timeline onto DVD 8.5GB with 4Hours with Good QLTY... and Blu-Ray the Same... All y project are alomost over 4 hours as i video indian weddings and events.
              i have made DVD's for customers with upto 4Hours on a DVD+r 8.5GB Media with good QLTY, but i now do about 3Hours per disc.
              Blu-Ray i do the Same as its HD
              Many thanks
              Dipesh Parmar (DIP)
                "Good" (or is it really "acceptable") quality depends on may things - the progarm material, the client's expectations, the system used to view the program, etc.
                For best subjective "quality" view on a small screen from a distance.
                  For me personally, if it doesn't meet my viewing requirements, it doesn't go out the door. When my name is on it and other possible clients will see my work, it has to represent me when I am not there.
