Hi,
I was checking the diferent options available within the "Consolidate Project" feature, and I am somewhat confused with the last option "Delete Unused files in Project"
When I consolidate a project, I am seeking to copy all files used in the project to the project folder, so I can backup my project easily in one folder, while keeping my original clips somewhere else.
With the "Delete Unused files..." option, Edius will delete the files that have not been used in the project, not only from the Consolidate folder, but from the original location where the files are!
Is this what it´s meant to be doing?
In my humble opinion, if I consolidate a project, I would like the files required to be moved to the Project folder, but I don´t want any files deleted from its original location.
Am I using this feature correctly?
