DVD Creator will not write to the DVD
    Well, thanks again for the info.
    There was no media in the drive when I took the screenshots.
    I haven't been able to try yet again.
    I'll keep you posted.
      Hi,
      I have tried with a Memorex 16x DVD media, with 2x as writing speed and still get the same message.
      Any more ideas please?
        as seen by your project settings, your project contains non DVD compliant audio
        all DVD must be 48k audio as minimum spec, you have it set to 44.1 for some unknown reason, always use 48k in anything video, the rest is for home movie makers :-))
          I had changed the audio settings to 48khz before I tried to record the DVD.
          I have always recorded my video projects at 4x with DVD Workshop 2 and never had a problem with it. With DVD Creator it will fail in my system no matter what the recording speed is.
            do a small test
            export a small section of your timeline to DV.avi after changing project to 48k
            create new sequence and add the above exported clip
            now try DVD Creator
            • #21
              do a small test
              now try DVD Creator
              Hi,
              I have tried what you suggested and unfortunately it does not work, I still get the same error message.
              • #22
                I have no further ideas at this stage
                • #23
                  I guess I will have to contact support.
                  • #24
                    Originally posted by Dasaecor
                    Hi,
                    When DVD Creator is about to start writing to the DVD, I get an error message "Other Error. Error success"
                    Anybody can help please?
                    I had an error similar to this - try it for kicks..
                    It turned out to be that the Markers were too close together on the timeline (DVD Creator makes chapters from the markers by default - you cant turn this off, like in Procoder Express!)
                    So save the file, then save a copy, remove all the Markers and try burning that! :-)
                    www.wishlistcentral.com - suggest new features
                    www.buglistcentral.com - report bugs
                    www.wishlistcentral.com/edius/ - Free edius user add-ons
