DVD Creator will not write to the DVD
  • DVD Creator will not write to the DVD
    Hi,
    When DVD Creator is about to start writing to the DVD, I get an error message "Other Error. Error success"
    Anybody can help please?
    Can you list the make/model of your burner drive and also the type of media you were trying to burn to?
      Sony DVD RW DRU-530A
      I was trying to record to a single layer DVD
        Same here, I have a Pioneer dvdrw dvr109.
          I have no problems with pioneer dvr 109.
          What burn speed have you selected?
            I have updated the firmware up to the last version, tried with two different discs, and still does not work, same error coming up.
              I have the 109 on my Storm system as well. Works fine here.
              Are you using a SATA to IDE converter by any chance???
                The DVD drive is IDE.
                  What are your project settings can you provide a screen shot?
                  Can you also provide a screen shot of your burn settings in dvdcreator?
                  SR
                    http://picasaweb.google.es/dasaecor/Borrar
                      Forbidden?
                      Ok I had to use IE .
                      2 things :
                      1 Why is your audio 44.100khz Dv is 48khz or 32 Khz. WHere does that 44.1 come from?
                      2 Don't use the max burn speed
                      check what your media is and burn at a lower speed.
                      example.:
                      Media 8x burn at 6
                      Media 16 burn at 8x
                      if you don't want to so that use the speed of the media
                      example
                      media 8 burn at 8
                      media 16 burn at 16
                      SR
                        Hi,
                        Thanks for your email.
                        I use 44.1 because this is what the final movie on the DVD will be capable of, isn't it?
                        I will try to save the project paying attention to max speed allowed by the burner and the media.
                        I will let you know if I have any luck.
                          If i am not wrong dvd is 48 khz audio cd is 44.1
                            DVD is 48 kHz, CD is 44.1 kHz
                              I forgot to tell you that your media is not recognized by dvd creator. At least in t he picture you posted.
