When recording, the camera sometimes captures very loud sounds, which are excruciating to scrub over, since I can't find a way to disable them in the preview window. Can someone help me to achieve this? I'm just trying to scrub the clips silently to dodge the noise, not removing the audio from them completely. Thank you for all your help!
How can I disable audio from preview window?
3,07 gigahertz Intel Core i7 950
64 kilobyte primary memory cache
256 kilobyte secondary memory cache
8192 kilobyte tertiary memory cache
64-bit ready
Multi-core (4 total)
Hyper-threaded (8 total)
12 Gb RAM
Board: ASUSTeK Computer INC. P6T DELUXE V2 Rev 1.xx
Bus Clock: 133 megahertz
ATI Radeon HD 4670
Edius 6.05
Windows 7 - 64 bit
Tags: None -
Unfortunately, there's no mute function from the player.
Using the Windows volume control takes the system focus away from Edius and stops playback.
The easiest way is to handle it externally.
I use a desktop mixer between my sound device and speakers.Rusty Rogers | Films
Twain - "Glances at History" 1906 -
I just hit the mute button on my Logitech keyboard.
This works instantly and doesn't affect playback.Edius 8.53WG, Vistitle 2.8, Windows 10 x64 Pro Fall Update, Asus Z87 Pro, Intel i7-4770K, 16 GB 1600 Corsair Vengence LP RAM, Samsung 840 Pro SSD 256GB, WD Black 2TB media drive, Intel HD 4600 GPU, MSI GTX660 2GB VGA, Coolermaster Silencio 652 case, Noctua NH-U12S CPU cooler, Cakewalk UA-25EX USB audio interface, Cakewalk MA-15D monitor speakers, BM Intensity Pro 4K, PlextorPX-LB950SA BD writer, Dell U2410 MonitorComment
Twain - "Glances at History" 1906Comment
