EDIUS 5 & BorisFX9 Can anyone help
This topic is closed.
  • EDIUS 5 & BorisFX9 Can anyone help
    What is the problem here in this picture?
    There is no CD I Download the program from Mediafire
    After installing the program ( Boris RED 4.3 )
    Note that I used EDIUS 5
    And i copy these files :
    BorisRED4_ED4TR.tpi
    BorisRED4_ED4FL.tpi
    BorisFX9_ED4FL.tpi
    BorisFX9_ED4TR.tpi
    Graffiti5_ED4FL.tpi
    and paste them in this path
    C:\Program Files\Canopus\EDIUS 5\PlugIn
    (: Hi
    your heading says edius 5 and boris 9. your question relates. boris red 4.3 these are two different programs. you also seem to have a foreign version from the pic I see.
    I have boris fx 9 loads fine from CD and as a download.
    download the trial software from boris fx website should work and use your serial number to unlock.
    SK Raja
    Adobe production suite cs5
    windows 7 ultimate 64bit Edius 6 Vitscene Mercalli Bluff Titler Boris FX
      no the heading is wrong
      i use this version
      Boris RED 4.3
      and ( Boris.Graffiti.v5.2.1 ) is ok
      (: Hi
        Did you buy the software?
          looks like dodgy software because the software pic shows looking for boris fx 9 dll. you can download the software trial version from boris fx website and then enter your serial number and getting working. providing you have purchased the software. if you are using pirate or dodgy then sorry I can't help. best advice buy genuine licence you can't go wrong plus you get support from boris fx.
          SK Raja
            This looks like Pirated software which we do not allow here.
