Short cut key for clip color?
  • Short cut key for clip color?
    I am using to categorize my clips with different colors. I have been searching for a shortcut key to assign to the different colors. I could not find it on the list.
    Is there any? I am using Edius 4.51c
    Dorian
    There isn't a shortcut specifically for this. The closest you can get is 'Alt + Enter' to bring up the clip properties window.
      Thank you!
      Dorian
