Problem when I have several video and graphic tracks.
  • Problem when I have several video and graphic tracks.
    Hi!
    Im editing with seven shorter (10 seconds) and two graphic tracks. If I move the graphic clip just a little bit Edius want me to render, again.
    The buffert says 148/149.
    Gah, I really like Edius but this is not so good.
    Is here anyone that know what the problem is?
    Johan
    If you have the computer horsepower it will do that
    in real time. Post your computer specs and which version
    of Edius. Also, what file format are the clips?
      Computer and Edius
      Hi!
      This is my computer:
      Intel Core 2 Quad CPU (Q8300, 2,5 Ghz)
      2 Mb RAM
      Windows 7 64 bit
      I have two harddrives. C: 75 gb (edius) and D: 1 TB (edius media)
      Edius version 5.12
      __________________________________________________ _____
      The videoclip, in this case, are 3GPP (from mobilephone). NOrmally I record with my JVC HDV GY-111e.
        P.s. My D: is a SSD-disc.
        Do I have to change something/upgrade?
        Thanks! Johan
          And... My graphic card is: Nvidia Quadro FX 1400
            I had the same problem when I upgraded to V6 so I went back to 5.5 as my computer just can't manage layered JPG's in V6 without rendering.
            Ron Evans
            Ron Evans
              I just noticed that you are still using 5.12.
              Go to the registered users section and upgrade to 5.51.
              Try the project again
              if that doesn't do rhe trick follow the rest if this post.
              Using a core 2 makes it under powered as well as the
              video card.
              Try this: convert your clips to HQ select all of
              your clips in the bin and right click>select convert
              batch convert and convert to HQ.
              If you have Photoshop convert the file to a
              .png. You could keep it .jpg and just reduce the resolution
              closer to 1920x1080(if you are not zooming)
              and see if that works.
              I think the HQ conversion will allow you
              to not have to change the stills at all.
                Hi!
                Sorry, I had 5.51.
                I guess that its my core 2 and also graphic card which are the problemmaker...
                Is there any other components you recommend? The cheapest...
                I have another question. I before hade Avid but Avid have many problems... I love Edius. But, is there any more graphic package to buy? With already made pictures like today but MUCH more?
                Johan
                  What do you mean by graphic package?
                  Are you talking about effects? If so Adorage
                  and New Blue effects have plugins for Edius.
                  The registered users section has Vitascene and New Blue
                  Effects. You will more than likely have to render
                  these two with your system.
                    >> You meant 2GB RAM NOT 2Mb RAM on your system ?
                    Add another 2GB RAM, you will see improvement !
                    Originally posted by Skanefilm2011 View Post
                    Hi!
                    2 Mb RAM
                    Windows 7 64 bit
                    Edius version 5.12
                    Asus P5WDH Deluxe w/E6600 - 4GB Corsair - 8800GTS - 1TB & 1.5TB (2x750GB RAID 0) - Antec P180 + Trio 650W - XP Pro w/sp3 - NX PCIe w/Expansion Card - Edius 5.51
                    Asus P6T i7 920 @3.6 - 12GB Corsair Dominator - GTX275 - 1.5TB & 3TB (2x1.5TB RAID 0) for Video - Antec P183 + Corsair HX-750W - Win7 - Edius 6.07 - Firecoder Blu - PC3.05.91 - BDR-203 - TMW5 & TAW5
                    Asus P6T i7 930 - 12GB Corsair - GTX260 - 1TB & 1TB WD Black for Video - Antec P183 + TPQ-850W - Win7 - Edius 6.07 w/HD Spark - BDR-205
                      Ohps, thats right.
                      Thanks for the tip.
                      I place the question again. When I´m opening quick titler there are some pictures to use (allready made). Is there any more already made pictures to use?
                      Im not using after effects by my self, so it would be great to have some more to choose between.
                        I now have 3x3 videoclips in the screen. Totally nine videotracks.
                        When I start quick titler and write a word, for example "editing". Then my computer do nothing. If I wait for three seconds then the word start writing. It take about 10-14 second before the word is wroten.
                        Is the problem then that I have only 2 gb ram?
                        Thanks for tip!! Its so sad.
                          You can check the "Window Task Manager" - "Performance" OR "Processes" to see the CPU & memory. Most likely the CPU is at 100% and not much free memory.
                          Adding memory is easiest upgrade you can do to improve your system performance for now (if your motherboard has empty memory slot).
