No Audio with Video
  • No Audio with Video
    Hi Everyone,
    When I bring in video footage to Edius 6.02 I drag it to the player
    window and play it, I can see the video playing but no audio. I drag
    the clip to the timeline the audio dosn't come with the video to audio
    line. THE AUDIO TRACKS ARE NOT LOCKED! I tried activating the A
    (audio) but it stay greyed out! I right click in the audio box and I notice
    in drop box A-connect source channel (audio) (toggle) 8 is greyed out.
    I can drag a song from a cd to the audio line it play's also in the player
    window. I right click on a clip in the clip bin go to properties and shows
    no audio. I am using DV tape. Audio problem started when Edius stop
    responding! I can't get this problem resolved! I need to finish a wedding
    project. I appreciate any help!
    Thank's
    Mitch
    Can you post a screen shot of your timeline?
    Also do you have gv hardware card and it it selected as preview device.
      Here are his screen shots Steve.
        Mitch,
        I got the profile and new project screen shots, but what I need is your actual profile that you export and save and a new project file without any clips in it.
        For profile:
        Go to System settings>Profile>right click on your icon>export>selected profile and save to a location. Email me that file.
        Then open a new project and send me the Edius Project File without any clips in it.
          Can you select anything in the little 'a' drop-down box? (In previous versions of edius, that's where you chose the audio that will be brought into that track.) If nothing is selected there (8 clears selection- that may be why it's greyed out- because nothing is selected to be cleared) no audio will go into that track. Try selecting 1 or 2 (or, if you like to edit stereo tracks/the clip has stereo audio then stereo 1&2)
            Mitch are the clip 32 Khz or 48 khz?
            And are you sure you captured audio because in EDIUS 6 you can capture Video only, Audio only and Video and audio.
            I would start by adding 2 a tracks.
            Check if the patches are on A 3 and 4.
            Enabling the to A is important. Click on the timeline press 8 on your keyboard.
              Mitch recapture a clip and choose video and audio
              as Steve suggested. This I believe is the whole
              problem.
                Hearing the audio while capturing does not mean you actually capture audio.
                It depends on selection.
                1 video only = Capture Video
                2 audio only = Capture Audio
                3 Video and Audio = Capture (F9)
                  No Audio with Video
                  Hi SL,
                  I am set at 48khz. I tried clicking on the timeline and pressing 8
                  on the key board. The A-audio will activate but when I drag video
                  with audio to timeline it grey out showing video with know audio!
                  After I capture a clip I click on it go to properties>clip properties
                  I fine file info- video info- expansion info- no audio info..
                  I tried clicking on the A- audio right under the V to activate audio
                  there it will activate but when I drag video with recorded audio to
                  the timeline it grey out!! Edius 5.5 audio was nothing like this!
                  Thank's for helping,
                  Mitch
                    So it is simple you are not capturing audio.
                    EDIUS can't magically provide audio if you are not capturing it.
                    How are you capturing?
                    Can you provide a screen shot of your device preset in .
                    Please stick to the facts no need to provide un-useful ballast info.
                      Mitch,
                      So now that the soundcard is working, did you get it to capture
                      audio?
                        You should also look if the device preset is setup correctly.
