angled split screen?
  • angled split screen?
    In Edius 5.5, is there a way to create a split screen diagonally, or in any other angle than parallel to the edges of the screen (i.e. horizontal and vertical)?
    Desktop: Edius 8.50 WG/Win 7 Pro/HP Z620/Intel Xeon E5-1620 @ 3.60GHz/16GB RAM/NVIDIA Quadro 4000/Storm 3G
    Laptop: 8.50 WG/Win 10 Home/ASUS ROG G751/Intel i7-4710HQ @ 2.50GHz/16GB RAM/NVIDIA GeForce GTX 970M
    U could try one of the 2D or 3D transition effects (or PIP - Picture in Picture) included in Edius and lock the angle at the required position by using it full clip length by use of locking the keyframe just right.
    E5.51 + E6.05 / NX HD / Win7 x64 / intel X3366 / 9800 GTX+
    Imaginate 2 / TMPGEnc VMW5 / TMPGEnc AW4 / WaveLab 4.
      The 3D Picture in Picture will allow you to get that effect.... in 5.5 you will need to render most likely.
      Best
      Dave.
      www.nakedeyedv.com
