Edius.exe encountered a problem
  • Edius.exe encountered a problem
    Hi, guys
    right now everytime I run Edius Pro 3.0, there's always a error dialog pop up, "Edius.exe encountered a problem and must be closed."
    It happens after I changed the graphic card in my PC since my old graphic card always makes my PC suddenly restart.
    I already installed the driver for the new graphic card (actually it's not a new one, I took it from my other PC).
    Since then, error dialog pop up everytime I run Edius.
    I already uninstall and reinstall Edius, however it doesn't the problem.
    My PC Specification is
    Pentium 4 2,8GHz
    1GB RAM
    Nvidia GeForce 5200
    80GB HDD
    LG LED Display 14"
    Anybody know the solution beside reinstall Windows? Thanks in advance.
    Did you configure the graphics card settings such as resolution and color depth (must be 32bit)
      I already setting the resolution & color depth
      into 1280X720 and 32bit.
      Edius still not running.
        what is your OS?
        which graphics card did you install?
          also, have you updated to Edius 3.62 which is free for registered users
            problem is solved.
            I reinstall windows. Btw I'm using Windows XP.
            Thanks, Anton. You always respond.
