Best Method for Split Screen?
  • Best Method for Split Screen?
    I have to do an HD720 split screen and am wondering which Edius tools would be most appropriate to do this?
    Ideally, I would like to have a clean white border line dividing the screen vertically in the middle.
    Thanks!
    Sincerely,
    Mike Truly
    Truly Media
    970.349.5651
    www.trulymedia.com
    System1: Edius 7.41|Storm Mobile|Dual Xeon 3.1 (20 cores w HT OFF)|128GB RAM|Dual 512 SSDs|7TB RAID5|Dual Quadro5000s|Win7_64
    System2: EdiusNX+Exp|Edius 6.03|Procoder3|XP32|Dual Xeon 3.6|4GB RAM|U320 RAID0 15K
    Hmmm... Layout seems to work pretty well with a Quick Titler vertical line. Although I wish there were some overlayed centerlines in Layout to help lay things out.
    Thanks!
    Sincerely,
    Mike Truly
    Truly Media
    970.349.5651
    www.trulymedia.com
      An easy way is to apply the push stretch transition and put start and finish at 50%. This will hold the transition.
      It also has a border setting.
      Maybe this can help.
      Sr
        Thanks SR! I'll give this a try.
        Sincerely,
        Mike Truly
        Truly Media
        970.349.5651
        www.trulymedia.com
          Region Filter with Solid Color on the Inside would also work, and let you position and size numerically.
            Brandon,
            Thanks I'll try this method too.
            Sincerely,
            Mike Truly
            Truly Media
            970.349.5651
            www.trulymedia.com
