Prior to using Edius 5.5, I used Multicam(a stand along program) to integrate different clips. They had a simple way to manually sync two different clips. First you marked the individual clip at a specific point, then you marked the others where you wanted to sync them, then there was a menu item: syn by clip mark, presto up to four cameras were instantly synced to the marks. In Edius, it is a bit confusing with the time codes and then and a asynchronus mode for manually aligning the tracks. I do not see a description on how to mark the tracks and then synchronize the tracks at the marks. Any help would be appreciated
