Region filter movement limitation
  • Region filter movement limitation
    At least in Edius 5.5, there appears to be a limitation to the positioning of the region filter so that it can't be moved even partially off-screen. For instance, trying to blur a face that comes and goes off screen and on again, while using an elliptical blur over face, gets problematic around the edges - I can't seem to move the blur bubble partially outside of the visible screen area, which leaves uncovered areas around the edges, since the bubble doesn't fit over the partially off-screen face anymore. Feathering the edges of the blur makes this even worse. Rectangular blur does fit against the screen edges tightly (when not feathered), but looks crude over a typically elliptical face.
    The only workaround I have is to lightly zoom into the image, so that the edges of the original image can be moved off-screen, and the bubble thus appears to be partially off-screen as well. But this only works after a Shift+Q mixdown into a new clip - otherwise just the original image is enlargened, but the region filter remains untouched, throwing your tracking off at every keyframe.
    Does anyone know a better method to do this? Has this been updated in version 6?
    Desktop: Edius 8.50 WG/Win 7 Pro/HP Z620/Intel Xeon E5-1620 @ 3.60GHz/16GB RAM/NVIDIA Quadro 4000/Storm 3G
    Laptop: 8.50 WG/Win 10 Home/ASUS ROG G751/Intel i7-4710HQ @ 2.50GHz/16GB RAM/NVIDIA GeForce GTX 970M
    In EDIUS 6 this is easy.
      Probably my favorite reason to upgrade to E6!
        Yes even does things that u would formally need ae to do. Am loving that feature all the way.
        EDIUS 9.5 /Win 10 x64 Dell T5600 INTEL Xeon 16 core @2.66GHz 32GB RAM /NVIDIA GEFORCE GTX 1660TI, SSD SAMSUNG 500GB PRIMARY, WD 5.5TB STORAGE, 2x WD500GB ASSETS, heroglyph 4.0, Sony AVCHD cam, Canon DSLRs.
        Sys 2: Asus ROG G75series
