Hi All.
Here are two files to download and play with. One is a Sony EX3 file and the other a simultaneous recording using HQX superfine over SDI with Thunder/Storm3G. The clips are only 5 seconds long because of file size. They are just an EX3 pointed out the window into a street. They are not going to win any cinematography awards, but they are fine to see the difference between 8Bit 4:2:0 and 10Bit 4:2:2 from the same shot and camera. The files are 1080P 25FPS.
I will be using the same clips to do a round trip grade test soon, to show the advantages or not using a 10Bit + workflow with 8Bit source footage that ends up back on an 8Bit delivery format.
HQX CLIP http://www.mediafire.com/?4ccfx7dwx2j8xvh
XDCAM EX CLIP http://www.mediafire.com/?wx0kjiw6krcs29b
Cheers.
Dave.
Cheers.
Dave.
