I have a 1280x720 HD project from Edius that will need to end up on a Blu-Ray disc played in a Blu-Ray player connected to an HDTV or projector that is capable.
I will be creating an Edius HD720 30p over 60p project consisting of animations rendered at 30fps with no fields. I have Procoder3 as well.
1. From the finished/rendered HQ files I need to convert these to what format for authoring into a Blu-Ray disc? MPEG2s? (I saw there was a post in the Procoder forum about Blu-Ray presets... I need to read that).
2. Blu-Ray authoring. I assume no Grass Valley products currently handle this so I will be using Adobe Encore CS3 to author (Does DVD-Lab do this yet?). Is Blu-Ray authoring accomplished in a similar fashion to authoring a SD DVD?
3. Blu-Ray burning. Is there a recommended burner or do they all work equally as well?
4. Blu-Ray players. I will be recommending one to my clients (as well as purchasing one for testing). Have others used players they would recommend?
Have others gone through this process (of delivering Blu-Ray dvds) sucessfully or should playback from computer be pursued?
Thanks for any ideas!
