Sorry if this is Edius 101, but that is about where I am at. I want to distort the image I have on track 2 to give it the same perspective as the screen hanging on the wall in track 1. I can resize and rotate track 2 but I cannot distort (break the corners) it to give it perspective. Any clues?...
Distort for perspective
Originally posted by STORMDAVE View PostAre you trying it with 3d PinP? You should be able to position it in 3d Space, although it's not 100% accurate, it is useful regardless.
...that's not possible, unfortunately
simple compositing just got a whole lot easier with v4.5's Select Channel filter (cheers!) but corner pin and distortion generally is still a pain in the proverbial. best bet is just to take the job to a different system or software that can better handle that and don't waste time trying to do it with an NLE thats not designed for it. it'll only aggravate you and distract you from all the stuff about Edius that is really pretty darn good.
Originally posted by Andy View Post... don't waste time trying to do it with an NLE thats not designed for it. it'll only aggravate you and distract you from all the stuff about Edius that is really pretty darn good.
Originally posted by Ricksta View PostYes I was using 3D PIP but it's just not allowing me to "break" the corners of the overlayed image and distort them to match the screen on the wall in the image underneath.
Depend on how much offset the corners are, it might crop a little on the edge, I do this all the time and it does not take long at all and all realtime. This is more realistic than if you could use 3DPIP to distorted and image, because if you look at the wall with your eyes, the picture does not distorted.I7-6900K, X99 Taichi, Geforce GTX 1070, Corsair RM850X, Corsair H100 IV2, Windows 10, Edius WG 9.30
