Field dominance analog capture 4.51c
    Yes it's also with a NX card plus Broadcast software because we have a SP and a NX.
    Fore the test i had to update the software first so that take's some time and now we know.
    Rob
    www.volkenkunde.nl
    Edius Broadcast 4.54| 3X SP hardware 1 NX | Dual Xeon 3.2 Supermicro | Carbon coder
      it gets worse!!!!
      place a Pal DV clip in an NTSC DV timeline, it will look out of focus and the field order will be wrong, changing the field order has no effect
      to overcome:
      export the Pal DV clip from Edius timeline using ProCoder3 and select NTSC DV avi
      then load the resulting clip in an NTSC DV project, it will be razor sharp and it has no field order flicker at all
        Hi everyone,
        I can confirm the problem on my SP system as well...
        Aristotelis Bafaloukos
        BEng (Hons), MSc, MBCS
        Ctrl+Alt+Delete
          At me the same problem with DV and D1. Edius SP - 4.51c. In the previous versions of such problems was not
