Do you mean the audio nodes? Then no, but it's a great feature request...you can post it in the appropriate forum.
As for copying an audio filter (such as EQ) it's very easy...all you do is drag and drop a filter from the Information window into the new clip that you want.
Yes you could just change the level in EQ without adjusting any frequency and this is a workaround for audio level paste. (-:
Yes I meant "volume nodes", sorry. In FCP it gives you the option to paste audio filters, pan and/or volume to one or many clips at once. Thank you both for your answers. I will try out the eq filter and paste.
Windows 10 Pro 64bit, Edius 7.53, Antec DF-85 Corsair 850Watt P/S,ASUS P6X58DE, Intel Core i7 960 3.20 Ghz Bloomfield,Corsair 12 GB RAM TR3X6G1600C8D-R,PNY GeForce GTX570 WD 600GB 10k RPM System Drive, WD Caviar Green Video Drives 1GBx2,G-Raid 2GB Backup Drive,Pioneer BDR-206 Blu Ray Drive
Thanks Anton. Panpot works but I have to copy and paste each clip one by one. It's a little faster then pasting node for node, but it still could be faster. Eq only goes as low as -12db and panpot goes to -83 db which is the same as mute I guess.Both panpot and eq have no correalation to the audio mixer or the nodes,ie: they both register 0db. I don't understand that. There already is a feature request posted similiar to this one.
Thanks all.
