Audio Playback Problem
  • Audio Playback Problem
    I performed noise reduction on a small 44.1 WAV file in Audacity and Audition. The file seems fine and plays back fine in both apps. Then I brought the files into Edius 4.24 and when I go to play them back, if I load them into the preview window they play fine but when I add them to the timeline, they play back very slow and stuttered. Then I loaded the original WAV and it does the same thing. Perfect in the preview, stuttered on the timeline.
    The original file was a 44K WAV and the Edius project a 48K. I converted the WAV to a 48K in Audition but I still get the same result.
    Any idea what I'm doing wrong?
    Thanks!
    Sincerely,
    Mike Truly
    Truly Media
    970.349.5651
    www.trulymedia.com
    System1: Edius 7.41|Storm Mobile|Dual Xeon 3.1 (20 cores w HT OFF)|128GB RAM|Dual 512 SSDs|7TB RAID5|Dual Quadro5000s|Win7_64
    System2: EdiusNX+Exp|Edius 6.03|Procoder3|XP32|Dual Xeon 3.6|4GB RAM|U320 RAID0 15K
    Ahhh, OK. I figured it out.
    Because I am now working in 720p, the additional resources required for playback of multiple layers in this rez are killing the audio playback.
    When I muted some video layers, the audio plays back fine.
    Thanks!
    Sincerely,
    Mike Truly
    Truly Media
    970.349.5651
    www.trulymedia.com
      Thanks!
      To avoid this type of mind bender you could go into settings and select the setting that says stop playback at frame drop. That way instead of stuttering playback it will stop and let you know when a frame is dropped. :)
        Thanks for the tips Mike!
        Sincerely,
        Mike Truly
        Truly Media
        970.349.5651
        www.trulymedia.com
          You are more than welcome :)
