Is it possible to change the parameters of the default audio fade in and out in Edius 6.02?
I know you can manually change the fade using the nodes but I would prefer a straight line fade in or out.
The standard default fade is not smooth enough for me.
UPDATE: Found where I was going wrong. I changed the waveform from Log to Linear. This produces a straight line fade. Makes no difference to the effect, but seems to me to be easier to change rather than a curved line with nodes
