Audio export problem with Edius 6.02
  • Audio export problem with Edius 6.02
    Hi, there is a problem,when I export my video files, that I cannot resolve.
    The project settings are ok ( the same of "Print to file".
    The settiings in "print to file" are ok for mpeg2,(in "print to file the codec for audio is set at 44,1kHz, 2ch, 256K, 16bit) but in "Mpeg2 program stream" the settigs automatically are, in audio setting "Format": Audio layer-2(ok), "channel":Stereo(ok), "bit rate": automatically go to 384K (I change it to 256K) but there isn't the sample rate.
    At the end of export all the files are at 48Khz.
    Where I can change it?
    Thanks for all your Help.
    Martino
    Audio at 44.1kHz is the standard for CD's. 48 kHz is used for DVD's.
    i7 3930K, Win 10 pro 64 Bit.
    RAM 32 GB.
    ASUS P9X79-Deluxe.
    PS Thermaltake 1kW.
    Graphics Gigabyte GTX1660 OC.
