I am unable to drop an audio crossfade on to multiple selected clips since upgrading. Have I missed something?
4.51c multiple crossfade problem
Hedley Wright
Partner - Brett Vale Studios
System: Mac Pro 2 x Quad-Core intel Xeon 6GB RAM, nVidia GeForce 8800GT 512MB, 2 BenQ FP937s 19" Wide Monitors, 200 Gb Bootcamp Window XP Pro partition, 550Gb OsX Leopard partition, RAID 0 Video drive 2 x 750Gb WD Caviar | Edius 5.11, NX ExpressTags: None
it appears to only work if the audio clips are on an audio trackAnton Strauss
does not work here, crossfade is added to last clip only
http://www.videoproductions.com.au/e...udio-trans.aviLast edited by antonsvideo; 08-15-2007, 01:37 AM.Anton Strauss
I tested again. It is strange. I put three color clips back-to-back at the beginning of the timeline, selected them all, then dragged an audio crossfade on. Only the last cut got a transition.
Then I moved the clips away from the beginning of the timeline, did the same, and all cuts got the transition.
Originally posted by GrassValley_BH View PostI tested again. It is strange. I put three color clips back-to-back at the beginning of the timeline, selected them all, then dragged an audio crossfade on. Only the last cut got a transition.
http://ediusforum.grassvalley.com/fo...ead.php?t=2084I7-6900K, X99 Taichi, Geforce GTX 1070, Corsair RM850X, Corsair H100 IV2, Windows 10, Edius WG 9.30
The clips are on A1 with associated video on V1. They have been trimmed and settings are set to extend clips on adding transition/crossfade. If this is broken it is a serious bug.Hedley Wright
