Audio disapeared in bin window
  • Audio disapeared in bin window
    Hi folks -
    I have been editing a number of interviews in the timeline. Once edited I did "add to bin window", named it and asigned a color for reference. Now, when I drag the clips back to the timeline, the audio is not there??? Can you please advise?
    Mark
    Mark
    Are you using split V/A or VA tracks?
      Hi,
      All is in the VA track.
      Mark
      Mark
        Can you give me a screenshot of your timeline ?
          This sounds like the Add to Bin limitation that the clip does not hold the audio and video link when brought back to the timeline.
          When you add them back to the Bin, does it split into 2 files or just one?
            I have the screen shotsn - how do I get them into my reply?
            Thanks for your patience
            Mark
              Scroll down below the reply message part and you will see a button that says Manage Attachments. Click that and it will allow you to navigate to your screenshot location and then upload it. One the processing is done it will be attached to your reply message and you can close the Manage Attachments box
                Sorry guys, I'm having "one of those days! I tried to upload the screen shot and found the pixels were way more than they should have been. I went back and did it again i.e. 620x280. Tried to upload again and then got the message:
                "Edius screen shot a.bmp:
                Your file of 508.6 KB bytes exceeds the forum's limit of 19.5 KB for this filetype".
                Now what do I do?...Thanks again!
                Mark
                  save as PNG and don't resize.
                    Thanks - Here it is.
                    Learning all the time!!! :(
                    Mark
                      I think this is a mapping issue.
                      What is this timeline before you drag to the bin or the timelinewhen the clips are brought back from the bin?
                      Also how many channels does your file contain and on which channels is the actual main audio?
                      In EDIUS 6 when you use a VA workflow it is different compared to EDIUS 5.xx.
                      You can have work the same way but it requires a extra step.
                      What could be the issue in this case is that when you had the files on the timeline the first time channel 1+2 landed on an A track. This gave you a mixed workflow of VA and split V/A . When you drug them to the bin the channels which where on the a track get split and landed in the bin as separate objects.
                      No reason to panic they are still in the file if the above is the case . :)
                        on the left of the timeline in the header, it says A34
                        right click A34 and then click clear all tracks, after that, it will work normal
                          Thanks once - you saved the day! A simple fix (when you know what to do!!)
                          And thanks all, for your replies!
                          Mark
                          Mark
