EDIUS not rendering timeline
  • EDIUS not rendering timeline
    Hi there! One thing has been happening to my EDIUS for a few weeks now. I'm editing and I apply effects that make the timeline impossible to read in real time. I try rendering all the timeline, but the red parts of the timeline turn yellow, and when I try playing over them, the video freezes again. So I keep rendering eternally without a sign of a solution. Does anyone know what could be happening?
    Thanks!
    3,07 gigahertz Intel Core i7 950
    64 kilobyte primary memory cache
    256 kilobyte secondary memory cache
    8192 kilobyte tertiary memory cache
    64-bit ready
    Multi-core (4 total)
    Hyper-threaded (8 total)
    12 Gb RAM
    Board: ASUSTeK Computer INC. P6T DELUXE V2 Rev 1.xx
    Bus Clock: 133 megahertz
    ATI Radeon HD 4670
    Edius 6.05
    Windows 7 - 64 bit
    5.51
    6.0
    6.01
    6.02
    please, give us a hint ....about the version, and about what for effects....
      Sorry, I have EDIUS 6.02.
      The effects I'm using are simply Diffusion and a bit of color balance, but it's the Diffusion effect that causes the problems in playback.
      64-bit ready
      12 Gb RAM
      ATI Radeon HD 4670
      Edius 6.05
      Windows 7 - 64 bit
        Hi Dock. Are you using the Diffusion effect from the Video Essentials for Edius bundle? If so, the version that was included with Edius 6 did have this rendering problem. You can download the updated version from our website:
        http://www.newbluefx.com/downloads/W...ius6Bundle.exe
          set in and out over non realtime area and press Shift+Q, done
            I'll try updating the video essentials with the link you provided.
            I'll keep in touch.
            64-bit ready
            12 Gb RAM
            ATI Radeon HD 4670
            Edius 6.05
            Windows 7 - 64 bit
              Having issues with audio not rendering . Glitches when it hits audio keyframes even after rendering the clip or rendering in-out all. Video has already been shift-q'd and there are only 4 stereo tracks.
              A couple audio tracks are 24 bit on a 16 bit timeline (1080 24p 8bit video, 16 bit 48k audio project). Running an i7 920 6gb ram.
                I have never seen an issue where rendering did not solve it. But can you convert the 24 bit audio to 16 bit and then try that?
                  This is a strange I have not seen a system yet which cannot play four tracks of audio in real time without any issue.
                  Unless of course mp3 is used?
                    I have seen this when the audio mixer is open and set to the wrong mode where the buffer will be depleted, then stutter happens
                      With four channels I have not seen it yet.
                        mixer was/is closed. It's really starting to p!ss me off! Never had this problem before.
                          what are the audio clip properties?
                          what is the buffer showing when stutter happens
                            Are you sure you don't have any thirdparty effect on the video above the clips which stutter?
                            To test create a new v track above the last video track . Disable the Audio (so you don't get tone), add a color bar in the V track. Now play back the timeline.
                            What happens?
                              Ill check this tomorrow.
                              I ended up printing audio to a file then importing that audio file onto another track and muted the others. Had to output for delivery yesterday so didn;t have time to check anything.
