Originally posted by Wilfred
View Post
Edius upgrader Install problem
Originally posted by GrassValley_KH View PostHave you ever installed/used a v4.xx demo?
Disks only since v1.0 ;{)
RustyRusty Rogers | Films
Windows has support for ZIP files built into it -- unless you install something that associates itself with ZIP files or installs a shell extension, Windows will open a ZIP file just like any other folder and let you add/extract/delete files.
Hi Kenneally,
Sorry for the delay, had to do some work.
I did have V4 demo on this computer originately. Does that make a difference?
VaughanMain Edit System ASUS Z170-Pro, 6700K, 32 gig ram HD Spark, Windows 7 64bit Edius 8.1 (Edit Machine)
VaughanOriginally posted by Wilfred View PostNo, a clean 4 install, only thing I can think of is the last BETA update. 4.3
When you uninstall the app, make sure that the "C:\Program Files\Canopus\EDIUS4" is removed. Also be aware that any other plug-ins you've installed for EDIUS will require a reinstall.
