Edius upgrader Install problem
  • Edius upgrader Install problem
    Just trying to upgrade Edius 4.03 to 4.51c, and the installer stops during preparing to install with the words of wisdom....
    "Different version of Edius was detected.
    The set-up will not proceed."
    Am I missing something here?
    Any suggestions?
    Thanks,
    Vaughan
    Further, I just tried upgrading to 4.10 with the same message.
    Think I have a real problem!
    Vaughan
      Hmm, there isn't any chance that some old v3 stuff is still on your system, or that you're trying to run v3 and v4 together on the same Windows XP partition/installation?
        Anybody else get this???
        Downloaded 4.51c twice today.
        Both times WinRAR Reports...
        ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in Drivers\HX-E1\FirmwareUpdater\data1.cab. The file is corrupt
        ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in EDIUS\data1.cab. The file is corrupt
        ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in EDIUS\data1.irt. The file is corrupt
        ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in EDIUS\data2.cab. The file is corrupt
        ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in EDIUS\data2.irt. The file is corrupt
        ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in EDIUS\Help\CHS\edius.chm. The file is corrupt
        ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in EDIUS\Help\DEU\edius.chm. The file is corrupt
        ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in EDIUS\Help\ENG\edius.chm. The file is corrupt
        ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in EDIUS\Help\FRA\edius.chm. The file is corrupt
        ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in EDIUS\Help\JPN\tmj.chm. The file is corrupt
        Rusty
          Can you try WinZIP? I just remembered that I was unable to open some ZIP files unless I used WinZIP....or try to get the latest version of WinRAR. I've downloaded the patch 3 times, each with zero errors....did you use a download manager?
            If you're using a download manager, don't.
              Firefox only, will try IE.
              Rusty
                IE download is no better!
                Anybody else get this? Again, WinRAR to unzip
                ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in Drivers\HX-E1\data2.cab. The file is corrupt
                ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in Drivers\RX-E1\data2.cab. The file is corrupt
                ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in Drivers\RX-E1\driver\CveMicroCore.dll. The file is corrupt
                ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in Drivers\RX-E1\driver\CveVnsHal.dll. The file is corrupt
                ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in Drivers\RX-E1\driver\vnscore.dll. The file is corrupt
                ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in Drivers\RX-E1\FirmwareUpdater\data1.cab. The file is corrupt
                ! C:\Editor Downloads\Canopus\Edius 4.51c\EDIUS4UPD_v451c.zip: CRC failed in EDIUS\Help\JPN\edius.chm. The file is corrupt
                This is my third try today! Getting a little nuts here!
                Rusty
                  If you're accessing Internet via a proxy, it might be caching a bad download.
                  Alternately, your browser might be caching a bad download, or part of one. Try clearing the browser cache.
                  If that fails, try a different method of Internet access, or at least a different machine.
                    I got the same result.
                    Ten times at least trying many different ways for download.
                    And I even try unzip with winzip.
                      Ok, I'm testing a download here to see that there isn't some corruption with the file server.
                      So that everyone knows, the details of the file are:
                      Size: 469 MB (492,272,536 bytes)
                      Date Modified: Thursday, August 09, 2007, 11:00:21 AM
                        Thanks for the ideas guys...
                        Downloaded to a different machine with a cleared cache and worked fine with Firefox!
                        Maybe worth a note on the download page to reduce more of these little nucences!
                        Rusty
                          I tested another download - WinRAR has zero complaints about the archive.
                          Definitely recommend a full browser cache flush if you're having problems, as well as the aforementioned non-use of download managers (particularly the ones that split+download)
                            I have the same problem as the first poster. Edius 3 was never on this pc.
                              Rusty
                              I use Firefox and it downloaded ok.
                              Mule
                              EDIUS v5.51 Broadcast - Dual Xeon Supermicro X7DWA-N with E5450 3.0GHz CPU (8 cores)
                              4 GB Ram, 1.0 TB Video Raid (2x500). 5 ea 1.0 TB External Video. 2 500 gb Ext, 320 GB OS Drive .. ATI Radeon HD 4350 with 512 Ram XP Pro with SP 3 HD Sparks, VisTitle
                              Edius 6.52Dual Xeon Asus P5E3 9650 3.0 4G Ram
                              Nvidia9800, 500G Raid (2x250) 1TB&500TB Ext Drives
                              HPX 2000 AVC Intra, HVX 200, HPX 170, AG-AF 100, Canon D5 MKll.....MacBook G4 w/VMWare FCP Edius 6.2
