hey Guys, Whats the Mean Difference between Edius Pro 5.5x or 6.02 & Edius Broadcast?
Edius Pro or Edius Broadcast
Many thanks
Dipesh Parmar (DIP)
Unreel Eyes - http://unreeleyes.com
Hardware Used with Edius: -
(3 x System with : - Intel i7 X990, Asus P6T Deluxe V2M/B, 24GB DDR3 Ram, Leadtek FX5000 & FX4000 Quadro Card, 2x 2TB Raid (1+0) Hard Disk Drive Setup, 6TB x 4 Network Storage Drive, Pionner & Sony Blu-Ray Drive, Firewire 800 + 400 PCI-e Card, Canopus NX PCI-e Card with Breakout Box, Canopus edius 6.51, 6.51, and edius 6.07).Tags: None
EDIUS Broadcast contained optional codecs such as XD CAM, P2 format support for broadcast users. Since version 5 of EDIUS, these codecs became standard and there was no optional Broadcast naming.
Therefore, if you buy version 5 or 6, it is really Broadcast varient anyway.AMD Ryzen 9 5950X, RTX 3080, 64GB RAM, EDIUS X WG.
Many thanks, i was thinking the same as i could not find broadcast versions to buy online.
Originally posted by shueardm View PostEDIUS Broadcast contained optional codecs such as XD CAM, P2 format support for broadcast users. Since version 5 of EDIUS, these codecs became standard and there was no optional Broadcast naming.
Therefore, if you buy version 5 or 6, it is really Broadcast varient anyway.Many thanks
Dipesh Parmar (DIP)
In Japan, there are 2 version of E6 on the market,
Standard Version (80,000Yen) and EDIUS 6 Broadcast Version (200,000Yen)
Only the Broadcast Version is included the following codec and function:
XDCAM HD/HD 422, P2 DVCPRO HD, P2 AVC-Intra50/100, GF, XF, MXF Capture, Proxy Editing
I'm pretty sure you get all those functions on Edius 6 over here, and they are missing from Edius Neo 3DVC Built Clevo P775DM3-G Laptop with UHD screen, 7700K [email protected], Geforce GTX 1060 6GB GPU, 500GB M.2 Primary, 1x 480GB SSD, 1x1TB M.2, 1x 2TB 5400RPM Video drives, external Blu-ray Optical
