2ch selected, HD Spark still sends 8 Ch
  • 2ch selected, HD Spark still sends 8 Ch
    I don't know if this is exactly an Edius issue, or an HD Spark one. In the HD Spark's control panel, under HDMI audio output settings, you can select either "8 Ch" or "Monitor 2 Ch". Even though I have "2 Ch" selected and the project is only 2 channels stereo, the card still sends 7.1 channels through the HDMI output, when I would prefer if it sent two channels, that way the receiver could use Dolby ProLogic IIx to create 5.1 the same way it will do when I finish the project and burn to BD or AVCHD.
    Since it's sending 7.1 channels to the receiver, even though 6 channels don't carry any audio, the receiver thinks it's a real 7.1 track and it doesn't allow Dolby to engage.
    Is there a way to make the HD Spark or do anything in Edius to make it send two channels only?
    My system
    Case: Cooler Master ATCS 840
    Motherboard: GIGABYTE GA-890FXA-UD5
    CPU: AMD Phenom II 1090T x6 @3.2 Ghz
    CPU Cooler: Cooler Master Hyper212+
    RAM: GSKILL F3-10666CL9Q-16GBRL 16 GB
    PSU: CORSAIR CMPSU-850TX 850W
    Video card: HIS Radeon 4850 1GB RAM
    Hard drives: 2 Western Digital Caviar Black Edition (one for OS, one for video), 1 WD Caviar 768 GB
    Optical drives: LG GBW-H20L Blu-Ray recorder, Pioneer DVR-217D DVD recorder, both SATA
    OS: Windows 7 Home Premium 64 bit
    How many audio channels is your project set up to support?
      Just two, stereo.
      My system
        Can you post a screen shot of the sequence mapping.?
          You mean what channel is mapped to what output? It's a simple sequence with an AV track and the title track, no other audio or video tracks. The footage is AVCHD coming from either a Sony HDR-AX2000, a Canon HF100 or a Panasonic HMC40, all of them stereo AC3.
          My system
            No I mean right click on the sequence tab -> sequence settings-> channel map.
            Take a screen shot and please post it.
            What you have done on the timeline is irrelevant at this point.
              There is a reason I asked for that screenshot.
              Lets leave it at that.
                OK, here it is.
                My system
                  Thanks for this one. Can you give me one more.
                  Click the change display style in the same panel and give me a screen shot of that .
                  thanks
                    Originally posted by andrew_hd View Post
                    Check Hardware setting tab- I think there is a setting there to degrade audio monitoring to 2 channels only. This what I remember from my HDThunder settings- normally it always sends 8 channels over HDMI (even if 6 of them are empty). Not sure if Spark has the same settings.
                    Andrew
                    Yes, that's what I posted, that the HD Spark control panel has an option between sending 8 channels or two channels, however, when selecting 2 channels, 8 channels are still sent through the HDMI cable, it's just that 6 of those channels have no audio. They do have a signal, but completely mute. The problem is the receiver still detects 8 channels, so it doesn't allow Dolby ProLogic IIx to engage, it just shows PCM and it shows the mapping on the display as if it was receiving a 7.1 audio signal. In other words, it shows exactly the same as if you were to put a Blu-Ray that is authored with 7.1 PCM audio.
                    I'm not even sure why the capability for 8 channels is included. I mean, as far as I can tell, Edius only edits in stereo or mono, it doesn't have 5.1 editing like Vegas, Premiere or FCP. You can work with 6 channels if you want, but you can only pan between left and right, not between LF, RF, SL, SR and Center. Am I wrong in this? Can you pan between 5 channels in Edius?
                    My system
                      thanks
                      Sure, here it is:
                      My system
                        Thank you! now I have what I needed.
                        I will get back to you on this I will check with QA and send them the info.
                          Cool, thanks.
                          My system
                            Correct, but there's more than just 5.1 editing, so there are scenarios when editing 8 independent channels is useful, especially in broadcast situations.
                              , but I was told it's not possible.
                              This is classic phrase for "we don't want to" .
                              You want example?
                              "FrieCoder Blu can not render level 4.1 H.264, it is not possible" .
                              Well, it is possible I use it via third party program, they just didn't want to do it.
