No Audio properties
  • No Audio properties
    Hi there,
    I have problem with Edius 5.5 when importing clip i don't see any audio
    No Audio properties
    Pleas note that i'm able to play mpg-2 clip in vlc or realaudio with sound !
    this stream was captured with vlc
    Please advice
    @ nour.............welcome on this "board"
    • a) importing = from harddisk to bin??
    • b) importing = from bin to timeline??
    No Audio properties
    • c) in the bin = mark clip with contex >> properties >> no audio tab aviable??
    • d) on the timeline = no waveform aviable
    if it is a) or / and c) => drag the stream-file to the MediaInfo Icon (or open the file with MediaInfo)
    go to text view >> save as .txt > load up as attachement ... or copy / paste the text in to your post
    this will help other users to analyze your audio problem
    MediaInfo ...this little and free tool should present at any NLE-PC
    if it is b) => and it plays with audio in the (Edius) player windows ... it is only a setting
    please, excuse my "fractal english, and friendly greetings from snowily Central€urope
      You may need to convert the clips to .avi, .mov, or wmv files....I cant remember getting vlc files to play
        The audio is probably under wrong PID number, and that's why Edius doesn't see it. You can probably demux the audio from this file with any transcoding software. (even with VLC)
        Dell T1650, 8GB ram, SSD, Win 7, Edius 6.08+HDSpark, Vistitle
          converting is not option it is time consuming,
          I'm using this command to capture stream ((Osprey 440 CARD) + VLC 1.1.7))
          vlc dshow:// :dshow-vdev="Osprey-440 Video Device 1D" :dshow-adev="Osprey-440 Audio Device 1D" :dshow-caching=200 :dshow-vdev="Osprey-440 Video Device 1D" :dshow-adev="Osprey-440 Audio Device 1D" :dshow-size= :dshow-aspect-ratio="16\:9" :dshow-chroma= :dshow-fps=0 :no-dshow-config :no-dshow-tuner :dshow-tuner-channel=0 :dshow-tuner-country=0 :dshow-tuner-input=0 :dshow-video-input=-1 :dshow-video-output=-1 :dshow-audio-input=-1 :dshow-audio-output=-1 :dshow-amtuner-mode=1 :dshow-audio-channels=0 :dshow-audio-samplerate=0 :dshow-audio-bitspersample=0 :dshow-caching=200 :dshow-aspect-ratio="16\:9" :sout=#transcode{vcodec=mp2v,vb=3072,scale=1,acode c=mpga,ab=128,channels=2}:duplicate{dst=std{access =file,mux=ps,dst="C:\saves\JeugdJournaal.mpg"}}
