6.02 and SPARK Problem
  • 6.02 and SPARK Problem
    Switching time is now around 5 seconds between Record and Player window
    Player window is being output at 1920x1080 25i and Monitor report signal as HDMI 1080i
    Recorder Window outputs as [email protected] Progressive???
    Monitor reports DVI 1 input instead of HDMI
    Anyone else having problems
    Regards Barry
    can you check the layouter of the clip in the rec window to make sure it says 1920x1080
      Yes it is definitely 1920x1080
      Problem seems to be with the overlay for the Spark card
      Depending how the monitor is switched off and on will bring the problem on
      Soft switch and problem re appears and can be made to swap between recorder and player monitor depending which one is selected at the time
      Reloaded QT and no change
      Reloaded the Graphics drivers and seem to have stability back
      Interesting note on this I had a similar problem about a week ago when I loaded the latest Vitascene 1.1.89 and was loosing all the overlay on Edius (both computer monitor and Spark) and had to reload the Graphics drivers
      I had just reloaded Vitascene as I could not register or get it to work properly and it seems the problem was 1.0.48 was still on the computer and was stopping the proper registering for 1.1 so maybe it had something to do with this
      If I have more problems I will dump it, don't use it much anyway
      So far so good
      Regards Barry
        maybe run the hardware driver installer again from the unzipped 6.02 download and then reboot
          Seemed to make it worse, and had to reload the Graphics card drivers to cure
          Came out this morning and re seated the card and the problem persists IF i turn the monitor off and then back on
          Selecting another input and then re selecting the HDMI input on the monitor or selecting the color bars in the Spark selection in Edius also cures the problem
          Could be the monitor or the HDMI switch that is in the cct
          all seems to be working OK at the moment with instantanious change over of windows
          Trying a different input to the monitor? maybe
          Thanks, no one else seems to have a problem so it is in my backyard
          Regards Barry
            Went back to 6.01 and everything is rock solid
            Installed 6.02 and the same problem of now occasional output of 50p from Spark when switching between Player and recorder for the first time
            Once the input to the monitor is broken and restored (HDMI Switch) and everything works OK from then on
            Must be something in the new Spark drivers and the way my monitor reports to it
            Regards Barry
              can you try installing just the spark driver from the 6.01 installer and leave 6.02 in place
