Up to now? There is no way to find out encoder of plug in , for Edius 6?
  • Up to now? There is no way to find out encoder of plug in , for Edius 6?
    I tested before , the Procoder 3.X and Carbon Coder 3.1X support Edius 5 very well, as plug in , the Edius 5 user could output expected format (audio or video ) file directly.
    But up to now, even I have tested both new version ProCoder(3.06) and Carbon Coder (3.17 ) ,
    it seems that they are not compatible with Edius 6, why ?
    There is no way to find out an Encoder plug in of Edius 6?
    There isn't a plugin for Edius 6. It will still work as a stand alone though. If you absolutely need the plugin, use Edius 5.5 on a different machine, that is what I do.
      I really want Carbon Coder as a encoding plug in of Edius 6
      Since the perfect performance of Carbon Coder, I really wish the new version Carbon Coder could act as a plug in feature of Edius 6.
      Otherwise I have to let Edius 6 create Canopus HQX AVI file, then adopt Carbon Coder to convert it from HQX AVI to M2V , etc.
      Or, find out a solution such as frame server ...
        Rhozet/Harmonic would need to write a plug-in for EDIUS 6.
        The plug-in software needs to support the application.
          You could even install this one : http://ediusforum.grassvalley.com/fo...ad.php?t=20141
          Engineer for Digital Point production ltd.
          Video & Video
          The Official Italian Forum for Techinical Support to EDIUS.
          http://videodintorni.forumfree.it
