Never had a problem and today suddenly Edius 5.51 crashed 3 times in a row after I imported dslr 1080p files from a canon 550d
Right after the import above text appears and the blue line which you see about halfway starts scrolling the screen in a loop for about 20 seconds and then edius crashes. It says that cseavchd.dll has caused the crash, anyone familiar with this?
My machine is a I7 950, nvidia gtx460 2gb, 12gb memory, win 7 pro 64 and it's a fresh installed system. I have edited another project 2 days ago with dslr files as well without a problem. The only thing that has changed since then was when I started tmpgenc because it needed to connect to the internet to check on the serialnr (my edit station is not connected)
When I connected to continue using tmpgenc windows update also downloaded and installed that malicious software removal tool (I forgot to disable automatic updates. Could that be the cause?
