Converting HDV to DV
  • Converting HDV to DV
    Hi,
    I have a question regarding converting HDV to DV in the Edius workflow. We are using HDV cameras (Sony FX1, Canon A1 and HV10) and capturing in Edius with Project Settings Generic OHCI HD 50Hz/HDCAM HDV 1080/50i, but our final output is to be 16:9 standard DVD format.
    So my question is: at point should we make the conversion from HDV to DV? From the camera into the computer? Or when the footage is already in the computer, change the Project Settings to Generic OHCI SD PAL/DV 50i 16:9, 48kHz and then output to 16:9 MPEG2? Or leave the Project Settings as HDV and just output to regular DV MPEG2 from the HDV timeline.
    I then have convert everything from PAL to NTSC, so it would be nice to find out at what point we should make that conversion.
    Desktop: Intel Vernonia-R Server Board, dual Xeon 5420 2.5Ghz (8 cores), Vista Ultimate 64 Bit, 12 GB RAM, NVidia 9800Gt 512MB graphics, 320 GB system drive, 2x1TB Seagate editing drives (not in RAID), 30 inch HP monitor.
    Laptop: Toshiba Portege R700 2.66 Ghz cpu, 4GB RAM, 500GB hard drive
    Leave the resolution as long as possible in High Def.
    The last step before authoring has to be the downconversion.
    Best choice is to use Procoder ( Express ) for downconversion during export to mpeg, but it is also possible to switch the settings to SD and export after that. The export itself will become significant faster and the internal Edius-scaler is not so bad.
    Canopus-stuff: EZDV,Raptor,Storm,NX,all EDIUS-versions, all Procoder versions, ADVC-series, Imaginate 1+2, and so on...... ;-)
      Best result is to use Procoder 2's Mastering Quality conversion to mpeg - much better than anything Express can do - direct from the HD timeline.
        mastering quality just makes sense with very special footage.
        Just variables like the motion detection and the seek-range is different to highest quality.
          So are you saying that they have fix the bug with jaggie edges when making MPEG2 straight from a HDV timeline? I did not see that in the readme of 4.24.
            What about converting to one of the Canopus HQ codecs during capture? Surely this would give much better performance when editing a timeline?
            Or, do you need an NX card with HD expansion for this?
            Also, would that cause loss in quality.
            Windows 10 Pro. Gigabyte Z370 Aorus Ultra Gaming mainboard, Intel i7-8700K processor, 32GB DDR4 3200MHz RAM, Radeon R9 270 2GB DDR5 Graphics.
            Samsung SSD Drives for system and mixture of SSD and 7200 SATA for video storage.
            Edius 9.50. Blackmagic Intensity Pro 4k
            Dublin, Ireland. PAL.
              I've asked this same question in the User-reported issues forum, but haven't seen a response posted yet. If the problem isn't fixed you should definitely not render directly from an HD timeline to SD MPEG2 in Edius, as the results have been unacceptable. The best workflow is therefore to capture your footage as HDV and put it in a widescreen DV project for editing, from which you can render SD MPEG2 no problem. If you need both HD and SD output work in HD and render back to HDV from the timeline, then import that HDV file into a widescreen DV project to generate the SD MPEG2.
              Basically, Edius will properly convert HDV to DV but not to MPEG2, and can convert DV to MPEG2.
                There is no loss in quality when capturing in the HQ codec and it makes it much easier on the CPU's while editing on the timeline.
                Keep in mind that the file size is about 4X the size of HDV so your harddrives will have to be up to it.
                Also, a Dual Core CPU should be enough to capture in HQ. I know that on a laptop when it was a Hyperthreading CPU it couldn't keep up but dualcore Laptop (three months later) had no problem at all. :)
                  In a HDV project (Pal), when I convert HDV to MPEG2/SD by PCE, the video seems blurry, especially on titles.
                  When I create a DV project, the sharpness is higher and titles fine.
                  Is a workarond to avoid this ?
                  Marc
                  System : W7 Ultimate - MB: Asus Z170 - I7 6700K - Ram 16 Go - SSD1 256 Go (OS/log) - SSD2 1To (rushes) - HDD 4To (save) - Nvidia Asus GTX970 - HDspark - Edius WG 9 - Vistitle 2.6 - Robuskey - Mercalli4 - Neat video - Ignite - Hitfilm4Pro - AV : Eset Nod32 - Others : Moniteur Sony 32-EX500 - Cam : Sony EX1-R - 2 x Sony PXW-X70 - 1 x Pana GH5
                  Edius in France
                    Originally posted by rsn108 View Post
                    Hi,
                    Keep it in HDV as long as you can BUT be aware artifacts CAN occur on Moving Horizontal and Verticle lines but a fix is available,
                    Look here http://ediusforum.grassvalley.com/fo...ead.php?t=5141
                    Instead of Procoder 3 Proceder Express works just as well
                    Regards Barry
                      Exactly, I've many artifacts with PCE (horizontal/vertical)
                      The link with Mark's solution seems great.
                      Surely , I'll try it !
                      Marc
                      Edius in France
