Again, Title Motion all working fine this end with real time overlay out no problems with my Quadro FX 560 card. Can not make it crash not matter what I do.
Titlemotion no preview external monitor
Win 10 pro, Intel Core i7 8700K, ASRock Z370 Extreme 4, 16 GIGs Corsair Vengeance 3000 Ram, Single SATA drives, Nvidia GTX 560.
www.flykam.com.au www.wagscapes.com.au
ok, I uninstalled 4.51c and installed 4.51
no more crashes and live preview, case closed for meAnton Strauss
I take some of this back
the crashes are still there but worse, Edius vanishes to desktop
however, realtime preview works
this needs urgent attentionAnton Strauss
wags,
Titlemotion here has NO live video output on a QuadroFX 3400.
Can you check and see if Quick Titler has live video output as well as checking if the 'Preview' button in Quick Titler shows the video output? Both don't work here and I'm curious if they work on your system since you have live output from Titlemotion.
Thanks!Sincerely,
Mike Truly
Truly Media
970.349.5651
www.trulymedia.com
System1: Edius 7.41|Storm Mobile|Dual Xeon 3.1 (20 cores w HT OFF)|128GB RAM|Dual 512 SSDs|7TB RAID5|Dual Quadro5000s|Win7_64
System2: EdiusNX+Exp|Edius 6.03|Procoder3|XP32|Dual Xeon 3.6|4GB RAM|U320 RAID0 15K
I've got my NX system working now with 4.51c - no output from TMP with geforce 6600 card - but I also can't make it crash - so far!
PaulEdius Edits at: http://www.vimeo.com/user781619/videos
What do you want checked live out or something else?Steve
Just tested with box checked and unchecked - same result - no live update - it only updates on save and exit
I also checked it makes no difference.Steve
If you add a title in de timline with TMpro and converted to a animation and save it an then open it again than you have realtime preview and in the fx mode.Rob
www.volkenkunde.nl
Edius Broadcast 4.54| 3X SP hardware 1 NX | Dual Xeon 3.2 Supermicro | Carbon coder
To add to this. You can then change it back to still and the live out keeps working for you so you can see the adjustments.Steve
No preview after the swich to still anymore!
Only if Edius communicate treu the inscriber 01234.via (FX renderfile) in de title map from you'r project and then you heve preview.Last edited by robsegaar; 08-11-2007, 10:17 PM.Rob
www.volkenkunde.nl
Yes you switch to still but and work. I you save as still it does not work any more. Just for positioning and using the tools.
SRSteve
