Any 4.51c upgrade issues for DVStorm users?
  • Any 4.51c upgrade issues for DVStorm users?
    I only use my Storm for Hardware mpeg encoding - otherwise it is disabled in windows. Am I likely to experience any problems going from 4.10 to 4.51c? I can't do a clean install without the full package.
    Hedley Wright
    Partner - Brett Vale Studios
    I just updated from 4.24 to 4.51 and haven't seen any problems with the Storm or any other problems. I really like some of the new features and the fixes in 4.51.
    Edius Workgroup 9, Edius X Workgroup, Gigabyte X299 UD4, Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz, 64.0 GB Corsair Memory, Windows 10 Pro 20H2
      Thanks for that - I'll give it a try as soon as I finsh my current project :)
      Hedley Wright
        Storm
        http://ediusforum.grassvalley.com/fo...ead.php?t=1874
        Check that link out.
        Trey Sharpton
        In His grip!
          Upgrade from 4.24 to 4.51c went without any problems. My present project loaded with no problems and have started working with it. So far I have experienced a freez problem at two occasions:
          1) when I opened the color bar matt in the bin and changed between different choices.
          3) when I used crop with soft borders in 3D PIP.
          Both occasions required a full reboot.
          I have the Storm installed but used the Generic OHCI setting because I was trying the much larger buffer setting.
          Peter
          Skanoer, Sweden
          Edius Pro 8, Imaginate 2, Intel i7 950 , 12GB DDR3, 5 TB, Windows Pro 10 Creative, 64bit, Encore CS5
