4.51c filter problem
  • 4.51c filter problem
    Hi, I really like the new release! But I have a problem that after I have put a filter on a clip, adjusted it and moved on in the edit, the info window refuses to show the presence of the filter if you return to the clip later, hence it's impossible to adjust. Is this a known bug and can you help please?
    Geoffers
    whoops, getting ahead of myself
    should of course be 4.51c!
      don't see that problem here.
        try putting on the Box keyer from the Xplode pro composer tab
          I don't have xplode pro installed at the moment.
          I tried all the other filter and they work just fine.
          Maybe it is a xplode pro thing?
            Yep, could be, I'll try with other filters. In the meantime any suggestions on how to do a PiP resize to have two video clips alongside each other?
              put them on top of each other.
              1on va 1 and the other on va2
                The problem has recurred again - this time with 3d pip filter from the keyers menu. Now the clip does not show the blue line indicating a filter on and the notification in the info window has disappeared. But the clip still plays with the effect (wrongly positioned at present) in place but I can't get at it to modify it. Anyone else having this problem?
                Geoffers
                  Make sure you are clicking on the bottom (keyer) section of the clip and not the upper part. Clicking on the top part of the clip shows filters, the bottom part keyers. This is working as expected on my install.
                  Q6600 Quad-Core2 [email protected], Asus P5K-E Wifi MB, 2GB DDR2-800 RAM, BFG 7900GTX OC 512MB, Edius NX PCI-E, Edius 4.52, Adobe Production Premium CS3, Windows XP Pro SP2
                    I am clicking on the lower section but still am not getting any indication in the information window. When I first put the filter on, it showed up as it should, but after editing elsewhere and then returning to the clip, there is no indication of any filters applied at all. Very odd.
                      What size is this particular track? At smallest track size, the keyer line is not visible.
                        Ahhh. That's the answer!! Thanks so much!
                        Phew!
