3D PinP problems
also send it to sr at ediussupport.com
no tiff but a psd with a transparent back groundSteve
Originally posted by Qframe View Post
When doing this there is a visible thin line that appears where the outside edge of the moving graphic is.
I got your email and it looked ok here on a PAL 16:9 project.
Check your email, I am sending back an exported avi file.
By the way, I couldn't load your .fic file?
I also could not load the fic.
I immediately went to: outline and a little drop shadow.
I send you the same psd with dropshadow and a little outer glow. Try it now see how clean it looks. Same Psd you made.Steve
Guys I’m still waiting to get the emails down. A client has send me a heap of big files.
But in the PSD I sent, it’s not the edge of the characters I’m talking about but the edge of the actual PSD frame.
Try these in the 3DPinP settings: Orirentation X:23 Y:54 everything else set to 0 (including crop) and then move the Scale slider back and forth (0 to 100) and where the actual edge of PSD is (transparent) you should see the line/distortion I’m talking about over the background.
I don't know why you could not load the presets??? something missing???
Yep Dave I did all that.
But have a look at this JPG attached. It is a still captured from the timeline.Attached Files
Did you try my psd?
Ok now I get it.
That looks like there could be something wrong.Last edited by SRsupport; 08-12-2007, 05:59 AM.Steve
Does that mean I’m not going mad?
Sorry I might not have explained it well before so I hoped that the still was Good enough to give you the idea.
I have tried using files from other sources eg 3D Studio Max, and Quick Titler and the same problem occurs. So I suppose it must be the 3DPinP Filter/Keyer.
As a temporary solution, you could try cropping the bottom by a few pixels (2-4?) in 3dPinP.
I will think of a few more things to look at, but if it looks ok on mine with the same exact (non modified) PSD that you sent me, then something is wrong on your side.
