4.51c problem
  • 4.51c problem
    Just installed the 4.51c update over the 4.51 version. Although TitleMotion now works without crashing, the length of the title on the timeline is the same as the length of the edit despite, in the settings, I have title length set at 4 seconds.
    I think this happened in the previous version (4.51) as well.
    Anyone else had this?
    Peter
    Edius NX
    Pete Silver
    Edius 7 Vistitle 2
    www.psilver.com
    Did you set an IN and OUT point on the timeline?
      Title length also depends the in and out point of the time line.
      Try this put an in and out so that the duration between the 2 is 6 sec.
      Make a new title.
      Tile will be made for duration of 6 sec.
      If you don't want that click on the time line press x.
      Title will be created to length of default settings.
      No problem. This has been explained very often :)
        4.51c Problem
        Thanks for that. I can see where I've gone different. I usually use the T in the bin to generate the title which generated the title at the default length. In the new version I was using the T above the timeline which does as you say,
        Problem solved!!
        Peter
        Pete Silver
        Edius 7 Vistitle 2
        www.psilver.com
