Edius 4.51 Title Motion Pro problems
  • Edius 4.51 Title Motion Pro problems
    Hi all;
    I love 4.51 (except for the problem with TMPro).....but it crashed after I put a TMPro title on one of my projects. I thought I had saved the title, but it saved the project (with the title on the main VA1 track) instead. Each time after opening Edius again, it crashed everytime I touched the title.
    I did however, save the project by reverting to Edius 4.24 where I was able to delete the title. I am about to re-install 4.51.
    I hope there are not any other problems I do not know about with 4.51.
    Andrew
    P.s. I hate being called a newby with only two posts, considering I was on the old forum and contributed for several years (though admittedly not much).
    Please read the other posts, this has been reported more than once and GV is going to release a fix for this.
      I really hope people reads other posts.
      There are of lot of us helping but going trough a 100 separate posts on the same subject is a bit discouraging.
      If all problems of the same nature are in one thread we can help all of you much more efficient :)
      Please help us help you.
      Thanks,
      SR
      SR
        I have the same problem. I worked around it by putting the title on the timeline without snapping it to the cursor - I then scrubbed over the title and everything works fine. I also crashed while working with the color controls for more than a min.
          4.51c fixes that problem. download and install it.
            can u give me the download site ?
              ah its ok i got it ... and well seems to me title motion pro worked fine
                There is also a problem when titles (Title Motion) in animation are shaking in rendering DV interface, which is probably caused by wrong fields rendering.
                Thank you
                mike
                Asus P8P67, Intel i7 2600K working at 4.50 Ghz, 16Gb Kingston RAM, Windows 7 64bit, 500Gb system drive, 320Gb Data drive and 1TB RAID-0 for AV, Edius NX Express, EVGA nVidia GTX 570 2.5CB DDR5, 750w ALTEC power and some creativity...
                  Hi!
                  Change in TMP to Animation. Menu - GO. There is a point called field dominance. Its set to upper field. Change it to lower field.
                  Wolfgang
                  Edius 4.54/3.62
                  NXe / RaptorRT2 max
